<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[The zoom in/out function stutters with Logitech Mouse]]></title><description><![CDATA[<p dir="auto">When zooming in/out the map the display stutters several times. The number of steps is different and does not depend on the selected map display.  I zoom with the mouse wheel one step, but the map zooms another 2 to 5 steps. With the +/- zoom button in the user interface this error does not occur. Also the zoom in/out on map.google works perfect.</p>
<p dir="auto">This error occurs when using a Logitech Mouse MX S2 with the mouse wheel set to scroll smoothly.<br />
I found a workarround for me, but it would be nice, if MyRouteApp would be fix this issue.</p>
<p dir="auto">Thanks</p>
<p dir="auto"><img src="/assets/uploads/files/1635579095256-logi-maouse.png" alt="Logi Maouse.png" class=" img-fluid img-markdown" /><br />
Workarround: <strong>Deactivate 'Smooth croll'</strong> in your device settings</p>
]]></description><link>https://forum.myrouteapp.com/topic/1720/the-zoom-in-out-function-stutters-with-logitech-mouse</link><generator>RSS for Node</generator><lastBuildDate>Fri, 16 Oct 2026 09:01:09 GMT</lastBuildDate><atom:link href="https://forum.myrouteapp.com/topic/1720.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 30 Oct 2021 07:38:36 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to The zoom in/out function stutters with Logitech Mouse on Fri, 19 May 2023 23:14:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mito" aria-label="Profile: Mito">@<bdi>Mito</bdi></a> I have a Logitech M330 Bluetooth mouse and I don’t have any issues with zoom wheel.</p>
]]></description><link>https://forum.myrouteapp.com/post/25814</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/25814</guid><dc:creator><![CDATA[Nick Carthew]]></dc:creator><pubDate>Fri, 19 May 2023 23:14:27 GMT</pubDate></item><item><title><![CDATA[Reply to The zoom in/out function stutters with Logitech Mouse on Fri, 19 May 2023 22:33:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mito" aria-label="Profile: Mito">@<bdi>Mito</bdi></a><br />
If your mouse doesn't work well with MRA just use the + and - zoom buttons.</p>
]]></description><link>https://forum.myrouteapp.com/post/25813</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/25813</guid><dc:creator><![CDATA[Lynchy67]]></dc:creator><pubDate>Fri, 19 May 2023 22:33:20 GMT</pubDate></item><item><title><![CDATA[Reply to The zoom in/out function stutters with Logitech Mouse on Fri, 19 May 2023 21:34:19 GMT]]></title><description><![CDATA[<p dir="auto">Exact same behaviour on current version of MRA (2023) and Logitech MX Master 3S. Mouse wheel set as "smooth" makes MRA zoom x4 steps. Google maps, Mapcarta, Tyre 9.16,... works perfectly, so it's clearly an unresolved MRA bug since 2021.</p>
]]></description><link>https://forum.myrouteapp.com/post/25811</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/25811</guid><dc:creator><![CDATA[Mito]]></dc:creator><pubDate>Fri, 19 May 2023 21:34:19 GMT</pubDate></item><item><title><![CDATA[Reply to The zoom in/out function stutters with Logitech Mouse on Sat, 30 Oct 2021 08:17:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-grimm" aria-label="Profile: Thomas-Grimm">@<bdi>Thomas-Grimm</bdi></a></p>
<p dir="auto">There are 18 specific steps of zoom in MRA Planner.<br />
I suspect that your Logitech mouse is set too sensitive.<br />
You might want to actually lower the sensitivity of the mouse wheel when working with MRA Planner.</p>
]]></description><link>https://forum.myrouteapp.com/post/10216</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/10216</guid><dc:creator><![CDATA[Steve Lynch]]></dc:creator><pubDate>Sat, 30 Oct 2021 08:17:35 GMT</pubDate></item><item><title><![CDATA[Reply to The zoom in/out function stutters with Logitech Mouse on Sat, 30 Oct 2021 08:01:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-grimm" aria-label="Profile: Thomas-Grimm">@<bdi>Thomas-Grimm</bdi></a><br />
Has this mouse worked well with MRA before?<br />
Have you tried the mouse with another card provider for example; Google Maps?<br />
Does the same happen there?</p>
]]></description><link>https://forum.myrouteapp.com/post/10215</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/10215</guid><dc:creator><![CDATA[TorqueRider]]></dc:creator><pubDate>Sat, 30 Oct 2021 08:01:23 GMT</pubDate></item></channel></rss>
