<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Route leads straight to endpoint]]></title><description><![CDATA[<p dir="auto"><img src="/assets/uploads/files/1795868637427-scherm-afbeelding-2026-11-28-om-13.23.32.png" alt="Scherm­afbeelding 2026-11-28 om 13.23.32.png" class=" img-fluid img-markdown" width="1744" height="1914" /> I’ve run into the following problem. I created a route for a club that starts at a restaurant and ends somewhere else—so, not a loop. I rode the route yesterday; when I set off from home and started the route, MRA directed me straight to the end point. I ended up having to navigate to the starting point myself and then start the route from there. I also wasn’t given an option to include the starting point when I first set off. Does anyone have any suggestions?<img src="/assets/uploads/files/1795868368145-img_8527.png" alt="IMG_8527.PNG" class=" img-fluid img-markdown" width="1320" height="2868" /> <img src="/assets/uploads/files/1795868383713-img_8528.png" alt="IMG_8528.PNG" class=" img-fluid img-markdown" width="1320" height="2868" /></p>
<p dir="auto">Stupid me found the solutions. I should have scrolled down to choose the starting point. Great addition btw.<br />
<img src="/assets/uploads/files/1795869744277-schermafbeelding-2026-11-28-om-13.40.36.png" alt="Schermafbeelding 2026-11-28 om 13.40.36.png" class=" img-fluid img-markdown" width="1320" height="2868" /></p>
]]></description><link>https://forum.myrouteapp.com/topic/13087/route-leads-straight-to-endpoint</link><generator>RSS for Node</generator><lastBuildDate>Sat, 28 Nov 2026 13:04:11 GMT</lastBuildDate><atom:link href="https://forum.myrouteapp.com/topic/13087.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 28 Nov 2026 12:20:19 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Route leads straight to endpoint on Sat, 28 Nov 2026 12:59:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nick-carthew" aria-label="Profile: Nick-Carthew">@<bdi>Nick-Carthew</bdi></a> Thanks, I just scrolled to the startpoint tap and there you can enter any point as starting point. I just tried a couple off routes and it seems that when you use your suggestion this will stay as a default. Which is great.</p>
]]></description><link>https://forum.myrouteapp.com/post/90572</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/90572</guid><dc:creator><![CDATA[Rolf Engelsman]]></dc:creator><pubDate>Sat, 28 Nov 2026 12:59:58 GMT</pubDate></item><item><title><![CDATA[Reply to Route leads straight to endpoint on Sat, 28 Nov 2026 12:44:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rolf-engelsman" aria-label="Profile: Rolf-Engelsman">@<bdi>Rolf-Engelsman</bdi></a> Before you tap the Start button, tap Routing settings and turn off Start from nearest waypoint.</p>
]]></description><link>https://forum.myrouteapp.com/post/90571</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/90571</guid><dc:creator><![CDATA[Nick Carthew]]></dc:creator><pubDate>Sat, 28 Nov 2026 12:44:10 GMT</pubDate></item></channel></rss>
