<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[F043 Cycel Map - plan in the app - plan in WebPlaner]]></title><description><![CDATA[<p dir="auto">Is that how it is?</p>
<p dir="auto">Unfortunately, it is not possible to plan a bike in the app with the "MRA route planner" although the bike map is offered, the bike is missing from the selection. So the route is also not allowed via cycle paths but only for example for the motorcycle.</p>
<ul>
<li>**Is it so that you can't plan cycling routes in the app? **</li>
</ul>
<p dir="auto">Routes that are planned in the WebPlaner for a bicycle are already displayed cleanly and could also be taken on the bike map.</p>
<p dir="auto"><img src="/assets/uploads/files/1795635846071-img_0565.jpeg" alt="IMG_0565.jpeg" class=" img-fluid img-markdown" width="1713" height="1285" /></p>
<p dir="auto"><img src="/assets/uploads/files/1795635856157-img_0566.jpeg" alt="IMG_0566.jpeg" class=" img-fluid img-markdown" width="1722" height="1281" /></p>
<p dir="auto">This is a route from the WebPlaner which can be traveled in the app with the OSM Cyclel map</p>
<p dir="auto"><img src="/assets/uploads/files/1795636361109-img_0568.jpeg" alt="IMG_0568.jpeg" class=" img-fluid img-markdown" width="1713" height="1300" /></p>
]]></description><link>https://forum.myrouteapp.com/topic/13055/f043-cycel-map-plan-in-the-app-plan-in-webplaner</link><generator>RSS for Node</generator><lastBuildDate>Wed, 25 Nov 2026 23:43:47 GMT</lastBuildDate><atom:link href="https://forum.myrouteapp.com/topic/13055.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 25 Nov 2026 19:59:29 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to F043 Cycel Map - plan in the app - plan in WebPlaner on Wed, 25 Nov 2026 21:30:37 GMT]]></title><description><![CDATA[<p dir="auto">Plannen met een fietskaart is zo irritant, het lijkt mogelijk, maar het is niet of je staat het online toe omdat alleen online OSM in de WebPlaner-server correct kan worden berekend.</p>
<p dir="auto">HEER kan dit helemaal niet in de app. <img src="https://forum.myrouteapp.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f914.png?v=06c51928fc7" class="not-responsive emoji emoji-android emoji--thinking_face" style="height:1.4em;width:auto;vertical-align:middle" title="🤔" alt="🤔" /></p>
<ul>
<li>het zou duidelijker moeten worden wat hoe het moet, het ontbreekt aan schone afbakening</li>
</ul>
]]></description><link>https://forum.myrouteapp.com/post/90387</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/90387</guid><dc:creator><![CDATA[Hubert Thoring]]></dc:creator><pubDate>Wed, 25 Nov 2026 21:30:37 GMT</pubDate></item></channel></rss>
