<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Can I compare routes directly in the library if they are in different subfolders?]]></title><description><![CDATA[<p dir="auto">Is it possible to compare multiple routes/track logs in the library outside of the route planner if they are not in the same subfolder? If I select a route/track in one subfolder and then switch to another folder to select a different route/track, the selection is lost and the heatmap for the folder is displayed. (I am familiar with the workaround using the route planner and the layer options.)</p>
]]></description><link>https://forum.myrouteapp.com/topic/12819/can-i-compare-routes-directly-in-the-library-if-they-are-in-different-subfolders</link><generator>RSS for Node</generator><lastBuildDate>Tue, 17 Nov 2026 17:50:52 GMT</lastBuildDate><atom:link href="https://forum.myrouteapp.com/topic/12819.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 17 Nov 2026 14:29:15 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Can I compare routes directly in the library if they are in different subfolders? on Tue, 17 Nov 2026 14:31:17 GMT]]></title><description><![CDATA[<p dir="auto">Indeed not possible.<br />
Won't be done.</p>
]]></description><link>https://forum.myrouteapp.com/post/89693</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/89693</guid><dc:creator><![CDATA[Corjan Meijerink]]></dc:creator><pubDate>Tue, 17 Nov 2026 14:31:17 GMT</pubDate></item></channel></rss>
