<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Mix between Search and Discover]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">Recently I need to use search function and tried both: Search and Discover.</p>
<p dir="auto">Search: finds a lot of results about text typed, but only shows distance to site discovered (I suppose from my site and in straight line)</p>
<p dir="auto">Discover: also finds a lot of entries about selection of type of POI, with his position on map</p>
<p dir="auto">I like the better of two worlds, so…</p>
<ul>
<li>Can search put results on map?</li>
<li>Can Search has and “Add all as POI” like Discover?</li>
<li>Can Search do not close when touch map and has option to search on area iagain as Discover?</li>
<li>Can Discover filter results by name added to group selection?</li>
</ul>
<p dir="auto">By example: I want to locate a Fast food restaurant (a determined brand).</p>
<ul>
<li>If I use Discover, the result is shown but no brand selection. I can move map and search again</li>
<li>If I use Search, a lot of results of that brand are shown with distance, but no position on map, so I do not know where they are. If I touch map, search results disappear.</li>
</ul>
<p dir="auto">And as a last.. if both panels are used, Discover is on top or search, so search results are not visible.</p>
<p dir="auto">I think a unique search function with best of actual two will be better.</p>
<p dir="auto">Regards</p>
]]></description><link>https://forum.myrouteapp.com/topic/12799/mix-between-search-and-discover</link><generator>RSS for Node</generator><lastBuildDate>Mon, 16 Nov 2026 20:11:35 GMT</lastBuildDate><atom:link href="https://forum.myrouteapp.com/topic/12799.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 16 Nov 2026 19:23:05 GMT</pubDate><ttl>60</ttl></channel></rss>
