<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Same order as the route list]]></title><description><![CDATA[<p dir="auto">Hi,<br />
I noticed that the sorting order of the same list in the main 'Library' section and in the planner's 'Library' section is not the same.<br />
Would it be possible to make them consistent?</p>
<p dir="auto"><img src="/assets/uploads/files/1794757768767-1.jpg" alt="1.jpg" class=" img-fluid img-markdown" width="707" height="605" /><br />
<img src="/assets/uploads/files/1794757772567-2.jpg" alt="2.jpg" class=" img-fluid img-markdown" width="428" height="735" /></p>
<p dir="auto">Thanks</p>
]]></description><link>https://forum.myrouteapp.com/topic/12760/same-order-as-the-route-list</link><generator>RSS for Node</generator><lastBuildDate>Sun, 15 Nov 2026 21:50:25 GMT</lastBuildDate><atom:link href="https://forum.myrouteapp.com/topic/12760.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 15 Nov 2026 15:49:36 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Same order as the route list on Sun, 15 Nov 2026 20:24:02 GMT]]></title><description><![CDATA[<p dir="auto">The Library page and the planner's Library section use the same sort setting, so they should always show the same order. In your planner screenshot the list is sorted by last modified, while the Library page is sorted by planned date. Most likely the planner was already open in another browser tab when you changed the sort in the Library, and a tab only picks up the new sort when it reloads. Reloading the planner tab (or picking the sort with the sort button in the planner's Library section) should make them match.</p>
]]></description><link>https://forum.myrouteapp.com/post/89526</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/89526</guid><dc:creator><![CDATA[Corjan Meijerink]]></dc:creator><pubDate>Sun, 15 Nov 2026 20:24:02 GMT</pubDate></item></channel></rss>
