<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Viapoints: tolerance range]]></title><description><![CDATA[<p dir="auto">I am referring to version V5, as I have not yet had the chance to test V6.<br />
I have noticed that if you set a waypoint (such as home, a hotel, etc.) and start the route from there without actually being at that exact location, the navigation system keeps trying to direct you back to it, even after you have moved away and are already heading toward the second waypoint.<br />
Would it be possible to introduce a calculation tolerance for waypoints (for example, 100 meters), so that the navigation system stops trying to send you back to the first point and instead recognizes that you are already on your way to the second one?</p>
<p dir="auto">Thanks</p>
]]></description><link>https://forum.myrouteapp.com/topic/12710/viapoints-tolerance-range</link><generator>RSS for Node</generator><lastBuildDate>Sat, 14 Nov 2026 10:30:41 GMT</lastBuildDate><atom:link href="https://forum.myrouteapp.com/topic/12710.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 14 Nov 2026 10:03:25 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Viapoints: tolerance range on Sat, 14 Nov 2026 10:23:04 GMT]]></title><description><![CDATA[<p dir="auto">This is fixed. There is a window of tolerance.</p>
]]></description><link>https://forum.myrouteapp.com/post/89351</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/89351</guid><dc:creator><![CDATA[Corjan Meijerink]]></dc:creator><pubDate>Sat, 14 Nov 2026 10:23:04 GMT</pubDate></item></channel></rss>
