<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Segment: route's engine]]></title><description><![CDATA[<p dir="auto">Hi,<br />
I noticed that in the Segments menu, the routing engine option appears when you create the first segment, but if you create additional ones afterward, the engine option no longer shows up, so it can't be selected to use different engines for different segments.<br />
It is always available in the routing settings, of course, but I think it would be very convenient if it remained visible directly in the Segments menu as well.<br />
Also, the OpenStreetMap engine wasn't listed under Segments—could it be added there?</p>
<p dir="auto"><img src="/assets/uploads/files/1794606261461-1.jpg" alt="1.jpg" class=" img-fluid img-markdown" width="428" height="927" /><br />
<img src="/assets/uploads/files/1794606305329-2.jpg" alt="2.jpg" class=" img-fluid img-markdown" width="428" height="968" /><br />
<img src="/assets/uploads/files/1794606269974-3.jpg" alt="3.jpg" class=" img-fluid img-markdown" width="1010" height="1167" /></p>
<p dir="auto">Thanks</p>
]]></description><link>https://forum.myrouteapp.com/topic/12706/segment-route-s-engine</link><generator>RSS for Node</generator><lastBuildDate>Fri, 13 Nov 2026 22:46:16 GMT</lastBuildDate><atom:link href="https://forum.myrouteapp.com/topic/12706.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 13 Nov 2026 21:45:32 GMT</pubDate><ttl>60</ttl></channel></rss>
