<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Merge toolkit: larger preview map]]></title><description><![CDATA[<p dir="auto">Hi,<br />
The preview map that appears in the toolkit's Merge menu is quite small, and I personally find it hard to see the details clearly.<br />
Since you are working inside that menu rather than on the main map while it's open, could the Merge menu area be expanded so that the preview map can be made larger as well?</p>
<p dir="auto"><img src="/assets/uploads/files/1794604381599-1.jpg" alt="1.jpg" class=" img-fluid img-markdown" width="1864" height="1260" /></p>
<p dir="auto">Thanks</p>
]]></description><link>https://forum.myrouteapp.com/topic/12700/merge-toolkit-larger-preview-map</link><generator>RSS for Node</generator><lastBuildDate>Fri, 13 Nov 2026 23:59:12 GMT</lastBuildDate><atom:link href="https://forum.myrouteapp.com/topic/12700.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 13 Nov 2026 21:13:04 GMT</pubDate><ttl>60</ttl></channel></rss>
