<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Frame the route "F" zoom out too much.]]></title><description><![CDATA[<p dir="auto">Hi,<br />
If I zoom in on a route and then want to view the entire route in full-screen mode ("F" shortcut), the "Search" and "Discover" bars end up covering a waypoint.<br />
I propose 3 solutions:</p>
<ol>
<li>
<p dir="auto">Reduce the width of the "Search" and "Discover" bars and adjust the "F" shortcut's view so that it excludes the vertical section of the map corresponding to the width of those bars.</p>
</li>
<li>
<p dir="auto">Configure the "F" shortcut so that it frames the route within the area on the map located below the "Search" and "Discover" bars.</p>
</li>
<li>
<p dir="auto">Move the "Search" and "Discover" bars into the route-planning menu, leaving the map completely clear and allowing them to be hidden along with the rest of the routing menu.</p>
</li>
</ol>
<p dir="auto"><img src="/assets/uploads/files/1794565689213-1.jpg" alt="1.jpg" class=" img-fluid img-markdown" width="1640" height="1259" /><br />
<img src="/assets/uploads/files/1794565694561-2-resized.jpg" alt="2.jpg" class=" img-fluid img-markdown" width="2156" height="1260" /><br />
<img src="/assets/uploads/files/1794565699104-3-resized.jpg" alt="3.jpg" class=" img-fluid img-markdown" width="2047" height="1259" /><br />
<img src="/assets/uploads/files/1794565704008-4-resized.jpg" alt="4.jpg" class=" img-fluid img-markdown" width="2186" height="1263" /></p>
<p dir="auto">Thanks</p>
]]></description><link>https://forum.myrouteapp.com/topic/12669/frame-the-route-f-zoom-out-too-much.</link><generator>RSS for Node</generator><lastBuildDate>Fri, 13 Nov 2026 11:05:45 GMT</lastBuildDate><atom:link href="https://forum.myrouteapp.com/topic/12669.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 13 Nov 2026 10:28:26 GMT</pubDate><ttl>60</ttl></channel></rss>
