<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[No waypoints on the map in the PDF]]></title><description><![CDATA[<p dir="auto">Regarding the creation of a PDF for an itinerary:<br />
Is it normal for the waypoints not to appear on the map, and instead only show up as a list?<br />
Is this a bug?</p>
<p dir="auto">I have attached some images.<br />
Keep up the good work, team!</p>
<p dir="auto"><img src="/assets/uploads/files/1794422243268-img_1076-resized.png" alt="IMG_1076.png" class=" img-fluid img-markdown" width="2732" height="2048" /><br />
<img src="/assets/uploads/files/1794422257522-img_1077-resized.png" alt="IMG_1077.png" class=" img-fluid img-markdown" width="2732" height="2048" /><br />
<img src="/assets/uploads/files/1794422270411-img_1078-resized.png" alt="IMG_1078.png" class=" img-fluid img-markdown" width="2732" height="2048" /></p>
]]></description><link>https://forum.myrouteapp.com/topic/12610/no-waypoints-on-the-map-in-the-pdf</link><generator>RSS for Node</generator><lastBuildDate>Wed, 11 Nov 2026 20:17:31 GMT</lastBuildDate><atom:link href="https://forum.myrouteapp.com/topic/12610.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 11 Nov 2026 18:39:06 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to No waypoints on the map in the PDF on Wed, 11 Nov 2026 19:51:28 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for the clear screenshots and the kind words!</p>
<p dir="auto">That's how it works right now, not a bug. The map in the PDF is a fixed overview picture of the whole route. It shows the line with the start and finish flags. The waypoints are listed underneath, each with the same number and icon it has on the planner map, along with arrival times.</p>
<p dir="auto">I've noted your request to show the numbered waypoints on the PDF map too. It's a good idea, especially for printed roadbooks, but it needs a different way of drawing the map. I can't promise when it will come.</p>
<p dir="auto">In the meantime, if you want a map picture with all waypoints on it, use the "Map image" tool in the planner (Toolkit). It lets you download an image of the route with numbered waypoints, which you can print beside the PDF.</p>
<p dir="auto">Have a great trip in Norway!</p>
]]></description><link>https://forum.myrouteapp.com/post/89009</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/89009</guid><dc:creator><![CDATA[Corjan Meijerink]]></dc:creator><pubDate>Wed, 11 Nov 2026 19:51:28 GMT</pubDate></item></channel></rss>
