<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[F027 Photos in a tracklog without GPS data can be added, but they are difficult to locate on the map and hard to delete.]]></title><description><![CDATA[<p dir="auto"><strong>If you add photos to a track after the fact, any images lacking location data such as the "screenshots" or cropped images you might create are automatically appended to the end of the track log.</strong></p>
<ul>
<li>Adding "Moments" (where you manually specify the location and add text) works well.</li>
<li>Adding "Photos" (which can be done with any image, though those without location data will be placed at the end of the track log) means the images will not appear on the map; they can only be accessed via the menu in the WebPlanner.</li>
</ul>
<p dir="auto">When you click on photos on the map, only those with GPS data or those added as "Moments" will appear. If you go to the WebPlanner menu on the left and select the view for all images, you can click on an image that lacks GPS data to display it—look for the "teardrop" icon in the bottom-right corner of the image. This will display that specific image, and it is only in this dedicated photo menu window that you can also delete it.</p>
<p dir="auto"><img src="/assets/uploads/files/1794311470769-screenshot-2026-11-10-124841.png" alt="Screenshot 2026-11-10 124841.png" class=" img-fluid img-markdown" width="337" height="216" /></p>
<p dir="auto"><strong>The process for locating and deleting photos should be improved:</strong></p>
<ul>
<li>The app lacks an option to delete photos; it only allows for adding them.</li>
<li>In the WebPlanner, locating and subsequently deleting photos that were added (labeled as "photo added") can only be done via the menu on the left. In contrast, photos associated with "moments" can be clicked on directly on the map and then edited via a small menu.</li>
</ul>
<p dir="auto"><strong>Photo 1 (The four photos here, which include GPS data, were taken while on the move.)</strong></p>
<p dir="auto"><img src="/assets/uploads/files/1794311182707-screenshot-2026-11-10-124251-resized.png" alt="Screenshot 2026-11-10 124251.png" class=" img-fluid img-markdown" width="2557" height="1143" /></p>
<p dir="auto"><strong>Image 2 (The photo in question has been added here as a screenshot)</strong></p>
<p dir="auto"><img src="/assets/uploads/files/1794311276977-screenshot-2026-11-10-124508-resized.png" alt="Screenshot 2026-11-10 124508.png" class=" img-fluid img-markdown" width="2551" height="1141" /></p>
]]></description><link>https://forum.myrouteapp.com/topic/12540/f027-photos-in-a-tracklog-without-gps-data-can-be-added-but-they-are-difficult-to-locate-on-the-map-and-hard-to-delete.</link><generator>RSS for Node</generator><lastBuildDate>Tue, 10 Nov 2026 12:26:14 GMT</lastBuildDate><atom:link href="https://forum.myrouteapp.com/topic/12540.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 10 Nov 2026 11:55:48 GMT</pubDate><ttl>60</ttl></channel></rss>
