<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[F024 Route selection – copying within MRA is still too cumbersome]]></title><description><![CDATA[<p dir="auto">Within the MRA WebPlanner, copying more than one carefully planned route—while retaining all the original MRA data—is currently quite cumbersome.</p>
<ul>
<li>
<p dir="auto">Copying a single route requires a workaround: you must first open it in the Planner and then save it as a copy.</p>
</li>
<li>
<p dir="auto">For multiple routes, the only option is to download them—a process that requires careful attention to the file format. Downloading more than one route always results in a ZIP file, which must then be unzipped before the files can be re-uploaded. When doing so, it is essential to select the <strong>new format: MyRoute-App (.mra "Complete Roundtrip")</strong>.</p>
</li>
</ul>
<p dir="auto"><strong>Suggestion: Add an option to copy routes directly into your own library within MRA.</strong></p>
<p dir="auto"><strong>Data sources: Clubs or friends</strong></p>
<ul>
<li>Enable multi-selection via the checkboxes on the left, and provide an option to copy the selected routes directly into your own library or a subfolder within your personal routes.</li>
</ul>
<p dir="auto"><strong>New field: "Copy to Library," located to the right of the "Download" button.</strong></p>
<p dir="auto"><img src="/assets/uploads/files/1794215871947-screenshot-2026-11-09-101629.png" alt="Screenshot 2026-11-09 101629.png" class=" img-fluid img-markdown" width="1500" height="1084" /></p>
]]></description><link>https://forum.myrouteapp.com/topic/12488/f024-route-selection-copying-within-mra-is-still-too-cumbersome</link><generator>RSS for Node</generator><lastBuildDate>Mon, 09 Nov 2026 13:03:12 GMT</lastBuildDate><atom:link href="https://forum.myrouteapp.com/topic/12488.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 09 Nov 2026 09:22:06 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to F024 Route selection – copying within MRA is still too cumbersome on Mon, 09 Nov 2026 12:34:55 GMT]]></title><description><![CDATA[<p dir="auto">I like the copy internally feature proposed.<br />
I've looked for it and found it missing. My use was having a number of collaborators developing a tour each with the ability to mess up any route, I wanted to copy the live set every now and then as a backup.</p>
]]></description><link>https://forum.myrouteapp.com/post/88549</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/88549</guid><dc:creator><![CDATA[Andy Nicholson]]></dc:creator><pubDate>Mon, 09 Nov 2026 12:34:55 GMT</pubDate></item><item><title><![CDATA[Reply to F024 Route selection – copying within MRA is still too cumbersome on Mon, 09 Nov 2026 12:22:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/corjan-meijerink" aria-label="Profile: corjan-meijerink">@<bdi>corjan-meijerink</bdi></a> : How about adding a feature within the library itself that allows you to select multiple routes at once and copy them internally? This would enable you to revise and adapt them elsewhere—for instance, by creating a new "2027" folder in your library—since you might want to change certain hotels or specific sections of the routes while keeping the originals intact.</p>
<p dir="auto">Note: I am currently planning a "2027 Black Forest" trip and have some routes from 2016 that I’d like to reuse but not exactly as they are; at the same time, I don’t want to alter the original versions stored in my "2016 Black Forest" collection.</p>
]]></description><link>https://forum.myrouteapp.com/post/88543</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/88543</guid><dc:creator><![CDATA[Hubert Thoring]]></dc:creator><pubDate>Mon, 09 Nov 2026 12:22:52 GMT</pubDate></item><item><title><![CDATA[Reply to F024 Route selection – copying within MRA is still too cumbersome on Mon, 09 Nov 2026 10:50:06 GMT]]></title><description><![CDATA[<p dir="auto">Hey, thanks for that! I’ll test it once it becomes available to us. Thanks a lot for the quick support!!</p>
]]></description><link>https://forum.myrouteapp.com/post/88513</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/88513</guid><dc:creator><![CDATA[Hubert Thoring]]></dc:creator><pubDate>Mon, 09 Nov 2026 10:50:06 GMT</pubDate></item><item><title><![CDATA[Reply to F024 Route selection – copying within MRA is still too cumbersome on Mon, 09 Nov 2026 10:08:34 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for the clear suggestion and the screenshot. We've built it, and it will be on the beta with the next update.</p>
<p dir="auto">When you tick routes in a club's, an event's or a friend's library, a "Copy to library" button now appears next to Download. You choose a folder in your own library, and the routes are copied straight in with all their waypoints, POIs and settings. You can tick whole folders too: their subfolders and routes come along. No ZIP, no unzipping and no file format to choose.</p>
<p dir="auto">For a single route there's also "Save a copy" in the ⋯ menu of a club route now, so you don't have to open it in the planner first.</p>
<p dir="auto">Let us know how it works for you!</p>
]]></description><link>https://forum.myrouteapp.com/post/88499</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/88499</guid><dc:creator><![CDATA[Corjan Meijerink]]></dc:creator><pubDate>Mon, 09 Nov 2026 10:08:34 GMT</pubDate></item></channel></rss>
