<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Discard-and-leave issues]]></title><description><![CDATA[<ol>
<li>Did this:</li>
</ol>
<ul>
<li>open an old route in planner</li>
<li>compare route engines; click button to force to same route</li>
<li>click on a library folder</li>
<li>prompted at exit: chose “discard and leave”</li>
</ul>
<p dir="auto">Result: that route is shown as modified “now”<br />
Expected result: it should have the old date still on it, as no changes were made</p>
<p dir="auto">On another route: I opened, reversed the route, reversed again, discarded changes: same thing happened - route erroneously marked as changed.</p>
<p dir="auto">This behaviour was not consistent when retested even when repeating the same operations on the same map.</p>
<ol start="2">
<li>Did this:</li>
</ol>
<ul>
<li>click “reverse”</li>
<li>click on folder name</li>
</ul>
<p dir="auto">Result: change was saved with no “discard or save” prompt<br />
Expected result: at exit, prompt to discard or save change<br />
I repeated this, reversing it again, and this time it prompted on exit.</p>
<p dir="auto">I have had a couple more times when it saved without prompting, so something is not 100% right there.</p>
]]></description><link>https://forum.myrouteapp.com/topic/12484/discard-and-leave-issues</link><generator>RSS for Node</generator><lastBuildDate>Mon, 09 Nov 2026 09:13:36 GMT</lastBuildDate><atom:link href="https://forum.myrouteapp.com/topic/12484.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 09 Nov 2026 07:35:57 GMT</pubDate><ttl>60</ttl></channel></rss>
