<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Suggestion: Make the layer icon permanently visible]]></title><description><![CDATA[<p dir="auto">Dear MRA Team,</p>
<p dir="auto">First of all, a big thanks for what you have achieved. It is truly amazing what you have accomplished.</p>
<p dir="auto">I would like to make the following suggestion for POI the library.</p>
<p dir="auto">Currently, when I click the POI Layers icon in the route planner, I see a list of all currently visible POI layers and can disable them individually.</p>
<p dir="auto">The issue is that once a layer is disabled, it disappears from the list. When all layers are disabled, the list becomes empty and the POI Layers icon itself disappears. As a result, there is no quick way to re-enable previously disabled layers from the planner. Instead, I have to go back to the POI Library and enable them again.</p>
<p dir="auto">I think it would be much more convenient if the POI Layers panel showed both enabled and disabled POI layers, with a checkbox or toggle for each one. This would allow users to quickly turn layers on and off directly from the planner without needing to return to the POI Library.</p>
<p dir="auto">This would make experimenting with different POI collections during route planning much faster and more intuitive.</p>
<p dir="auto"><img src="/assets/uploads/files/1794073727510-8d3d5606-12ea-489a-85bc-b31bb81f8928-image.jpeg" alt="image.jpeg" class=" img-fluid img-markdown" width="516" height="415" /></p>
<p dir="auto">Thanks</p>
<p dir="auto">Hans</p>
]]></description><link>https://forum.myrouteapp.com/topic/12449/suggestion-make-the-layer-icon-permanently-visible</link><generator>RSS for Node</generator><lastBuildDate>Sat, 07 Nov 2026 19:37:36 GMT</lastBuildDate><atom:link href="https://forum.myrouteapp.com/topic/12449.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 07 Nov 2026 17:58:13 GMT</pubDate><ttl>60</ttl></channel></rss>
