<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[What is new in Studio 0.2.2?]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">what is new in Studio 0.2.2?</p>
]]></description><link>https://forum.myrouteapp.com/topic/12394/what-is-new-in-studio-0.2.2</link><generator>RSS for Node</generator><lastBuildDate>Fri, 06 Nov 2026 21:01:34 GMT</lastBuildDate><atom:link href="https://forum.myrouteapp.com/topic/12394.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 06 Nov 2026 16:57:46 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to What is new in Studio 0.2.2? on Fri, 06 Nov 2026 18:42:32 GMT]]></title><description><![CDATA[<p dir="auto">I am extremely impressed with this studio and was playing with it last night importing tracklogs and photos and it works really well</p>
]]></description><link>https://forum.myrouteapp.com/post/88000</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/88000</guid><dc:creator><![CDATA[stuart marritt]]></dc:creator><pubDate>Fri, 06 Nov 2026 18:42:32 GMT</pubDate></item><item><title><![CDATA[Reply to What is new in Studio 0.2.2? on Fri, 06 Nov 2026 18:41:31 GMT]]></title><description><![CDATA[<p dir="auto">Ok, thank you very much. <img src="https://forum.myrouteapp.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f44d.png?v=06c51928fc7" class="not-responsive emoji emoji-android emoji--+1" style="height:1.4em;width:auto;vertical-align:middle" title=":+1:" alt="👍" /></p>
]]></description><link>https://forum.myrouteapp.com/post/87998</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/87998</guid><dc:creator><![CDATA[Jörgen]]></dc:creator><pubDate>Fri, 06 Nov 2026 18:41:31 GMT</pubDate></item><item><title><![CDATA[Reply to What is new in Studio 0.2.2? on Fri, 06 Nov 2026 18:13:21 GMT]]></title><description><![CDATA[<p dir="auto">0.2.2 is a small release with one fix: when you import photos, Studio now reads the GPS position stored in the photo and puts it on your route straight away. Before, it asked you to place each photo by hand, even when the photo had a position. If the photo also has a GPS time, Studio uses that as the capture time, so it lines up better with your tracklog.</p>
<p dir="auto">In case you skipped 0.2.1, that one brought two changes:</p>
<ul>
<li>An available update now shows up as a clear prompt in the middle of the screen, so you can install it or dismiss it. Before, it was a small chip that was easy to miss.</li>
<li>A Full export no longer gets stuck at 0% when the video encoder stalls. Studio gives up after 10 seconds and does the export the standard way, and Cancel stops it right away.</li>
</ul>
]]></description><link>https://forum.myrouteapp.com/post/87979</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/87979</guid><dc:creator><![CDATA[Corjan Meijerink]]></dc:creator><pubDate>Fri, 06 Nov 2026 18:13:21 GMT</pubDate></item></channel></rss>
