<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Daily hour limit]]></title><description><![CDATA[<p dir="auto">Hello,<br />
might it be useful to also add a limit on the total number of hours for the day's journey, for example to avoid arriving after dark?</p>
<p dir="auto"><img src="/assets/uploads/files/1793963666173-5bcba8b7-9d3c-4695-bf34-bc2e474d44f3-image.jpeg" alt="image.jpeg" class=" img-fluid img-markdown" width="447" height="733" /></p>
]]></description><link>https://forum.myrouteapp.com/topic/12372/daily-hour-limit</link><generator>RSS for Node</generator><lastBuildDate>Fri, 06 Nov 2026 13:53:52 GMT</lastBuildDate><atom:link href="https://forum.myrouteapp.com/topic/12372.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 06 Nov 2026 11:14:29 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Daily hour limit on Fri, 06 Nov 2026 11:57:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/corjan-meijerink" aria-label="Profile: Corjan-Meijerink">@<bdi>Corjan-Meijerink</bdi></a><br />
Thanks for the feedback Corjan.<br />
I understood that the limit in the planner refers to driving hours, it’s explicitly stated, which is great.<br />
My suggestion is slightly different: what if the planner could indicate the total duration of the daily trip, including stops?<br />
For instance, if I have a deadline, like needing to arrive at my hotel within 6 Pm but my planned departure time and the distance to cover would result in an arrival time past 6 PM, the planner could trigger an alert.<br />
This would let me know that I either need to leave earlier in the morning or plan for a shorter distance.<br />
What do you think?</p>
]]></description><link>https://forum.myrouteapp.com/post/87885</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/87885</guid><dc:creator><![CDATA[Corrado Miniati]]></dc:creator><pubDate>Fri, 06 Nov 2026 11:57:43 GMT</pubDate></item><item><title><![CDATA[Reply to Daily hour limit on Fri, 06 Nov 2026 11:39:21 GMT]]></title><description><![CDATA[<p dir="auto">The hour limit already works the way you suggest: it is riding time only. Stops you add on waypoints (a pause time) are not counted. In your example, 9:00 to 20:00 with two 2-hour stops counts as 7 hours of riding against your limit, not 11.</p>
]]></description><link>https://forum.myrouteapp.com/post/87877</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/87877</guid><dc:creator><![CDATA[Corjan Meijerink]]></dc:creator><pubDate>Fri, 06 Nov 2026 11:39:21 GMT</pubDate></item></channel></rss>
