<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Make a POI also to a Favorite]]></title><description><![CDATA[<p dir="auto"><em>I searched, but did not found another similar suggestion, therefor this one from me:</em></p>
<p dir="auto">It's possible to import own POI and organise them in Folders and Groups. Fine <img src="https://forum.myrouteapp.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f499.png?v=06c51928fc7" class="not-responsive emoji emoji-android emoji--blue_heart" style="height:1.4em;width:auto;vertical-align:middle" title=":blue_heart:" alt="💙" /></p>
<p dir="auto">But maybe you have importet a list of Bikerhotels, organised in a Group - but only one or a couple are really fine for you and would be primarily used. Then it's not easy to find them in the Group.</p>
<p dir="auto">Yes, I know there is a search function. But it would be more convenient (and permanent), if you could <strong>edit a POI and mark it as Favorite too</strong>. May by having a checkbox in the edit form, below "Keep on map".<br />
Because we now have also Folder/Group structure in Favs, in such a situation (you marked a POI as Fav), a question should popup: "in wich Folder/Group?".<br />
Or maybe, simply copy into the root folder of Favs - and you can move it afterwards from there wherever you want it to have.<br />
Would be quicker (and with same information) as creating manually from POI to FAV.</p>
<p dir="auto"><img src="/assets/uploads/files/1793960476882-poi_to_fav.jpg" alt="POI_to_Fav.JPG" class=" img-fluid img-markdown" width="1052" height="634" /></p>
]]></description><link>https://forum.myrouteapp.com/topic/12369/make-a-poi-also-to-a-favorite</link><generator>RSS for Node</generator><lastBuildDate>Fri, 06 Nov 2026 13:53:57 GMT</lastBuildDate><atom:link href="https://forum.myrouteapp.com/topic/12369.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 06 Nov 2026 10:23:01 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Make a POI also to a Favorite on Fri, 06 Nov 2026 10:34:44 GMT]]></title><description><![CDATA[<p dir="auto">It’s not a bad idea. Up until now, I’ve been saving key points along a route as favourites. That way, if you have to cut the trip short whilst on the road – perhaps due to the weather or something similar – you can head straight back to the hotel or wherever.<br />
I’ve deleted these favourites after the trip, otherwise the folder gets too cluttered.<br />
Now there’s the option of subfolders, and you could assign them to a planned trip.<br />
So, temporarily assigning favourites and/or POIs to a trip, or something like that, would certainly be handy.<br />
I need to give it some more thought.</p>
]]></description><link>https://forum.myrouteapp.com/post/87867</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/87867</guid><dc:creator><![CDATA[Jörgen]]></dc:creator><pubDate>Fri, 06 Nov 2026 10:34:44 GMT</pubDate></item></channel></rss>
