<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Allow the last entered point to be set as a via point]]></title><description><![CDATA[<p dir="auto">When I’m working my way through creating a route, I often build up the route from point to point, rather than entering the destination point first.</p>
<p dir="auto">So I click on a spot for my next waypoint and it is correctly added to the end of the route.<br />
However If I now change that final waypoint to a via point (6 in this example):<br />
<img src="/assets/uploads/files/1793951927335-img_2340.jpeg" alt="IMG_2340.jpeg" class=" img-fluid img-markdown" width="1356" height="700" /></p>
<p dir="auto">Then add another waypoint (7), it silently turns my via point (6) back into a shaping point:<br />
<img src="/assets/uploads/files/1793951985333-img_2341.jpeg" alt="IMG_2341.jpeg" class=" img-fluid img-markdown" width="1713" height="1158" /></p>
<p dir="auto">This is a slight variant of a behaviour in the previous planner which I found annoying. It treats the last point you have entered as some kind of special case. Actually, if I’m entering a route point by point, I want to be able to mark that as a waypoint or via point as I would do for any point in the middle of the route, and then move on with the next point in my map, expecting it to remain what I’ve set it as.</p>
<p dir="auto">(If for internal reasons you need the endpoint to be different from a viapoint, why not just do that conversion at the point of saving?)</p>
]]></description><link>https://forum.myrouteapp.com/topic/12366/allow-the-last-entered-point-to-be-set-as-a-via-point</link><generator>RSS for Node</generator><lastBuildDate>Fri, 06 Nov 2026 09:48:30 GMT</lastBuildDate><atom:link href="https://forum.myrouteapp.com/topic/12366.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 06 Nov 2026 08:09:22 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Allow the last entered point to be set as a via point on Fri, 06 Nov 2026 09:38:56 GMT]]></title><description><![CDATA[<p dir="auto">Yes I know. My point is that when I am creating a route step by step I dont want this counterintuitive logic:<br />
1 create point which is automatically a via point; enter notes, set up icon, etc<br />
2 add next point<br />
3 go back and edit 1 to make it a via point because it has changed itself.</p>
<p dir="auto">That constant backtracking is what I have always had to do but in the beta there is a nice easy button to explicitly make it a via point as I go along. So all I’m asking for is that it sticks.</p>
]]></description><link>https://forum.myrouteapp.com/post/87842</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/87842</guid><dc:creator><![CDATA[Anonymouse]]></dc:creator><pubDate>Fri, 06 Nov 2026 09:38:56 GMT</pubDate></item><item><title><![CDATA[Reply to Allow the last entered point to be set as a via point on Fri, 06 Nov 2026 09:17:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/anonymouse" aria-label="Profile: Anonymouse">@<bdi>Anonymouse</bdi></a> ...the entered last point is always a Via Point (because you wnat definitively reach it).<br />
If you enter a new last point, this wil become a Via Point and the former last point turns to Shaping Point...</p>
]]></description><link>https://forum.myrouteapp.com/post/87841</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/87841</guid><dc:creator><![CDATA[Guzzist]]></dc:creator><pubDate>Fri, 06 Nov 2026 09:17:05 GMT</pubDate></item><item><title><![CDATA[Reply to Allow the last entered point to be set as a via point on Fri, 06 Nov 2026 08:46:32 GMT]]></title><description><![CDATA[<p dir="auto">I don’t want to go back and add things later, I want to build my route up point by point. So I click on a village, and I want to make that a via point. The new app (unlike the old one) appears to let me do that. I just want that to do what it says, not to automatically and silentlyturn it back into a shaping point when I add the next point on my route.</p>
<p dir="auto">That seems to me to be the intuitive behaviour. Of course many people will have already entered the start and end point and be building a route from the middle, but not everyone works that way.</p>
]]></description><link>https://forum.myrouteapp.com/post/87837</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/87837</guid><dc:creator><![CDATA[Anonymouse]]></dc:creator><pubDate>Fri, 06 Nov 2026 08:46:32 GMT</pubDate></item><item><title><![CDATA[Reply to Allow the last entered point to be set as a via point on Fri, 06 Nov 2026 08:40:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/anonymouse" aria-label="Profile: Anonymouse">@<bdi>Anonymouse</bdi></a></p>
<p dir="auto">I don't see why this must be changed, It works fine asi it is now.</p>
<p dir="auto">You can mark "last point" wile you are creating your route line with a color to identify later to add pause, text, or other indications.</p>
<p dir="auto">This behavior is from first days of planner, not new.</p>
<p dir="auto">Regards,</p>
]]></description><link>https://forum.myrouteapp.com/post/87836</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/87836</guid><dc:creator><![CDATA[Lluis Arasanz]]></dc:creator><pubDate>Fri, 06 Nov 2026 08:40:15 GMT</pubDate></item></channel></rss>
