<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Change the logic for assigning waypoints via the "search" function?]]></title><description><![CDATA[<p dir="auto">Hello,<br />
I’ve noticed that the waypoint management window differs depending on whether you click a point on the map or use the "search" function.<br />
In the latter case, wouldn't it be more convenient if the searched location were assigned as a waypoint by default (as this is likely the most common use case), with the option to change it to a POI via the menu that appears when you click on the waypoint itself?</p>
<p dir="auto"><img src="/assets/uploads/files/1793794802530-58cab45c-eb52-4d05-a0da-9c55d5e16e8c-image.jpeg" alt="image.jpeg" class=" img-fluid img-markdown" width="1692" height="900" /></p>
]]></description><link>https://forum.myrouteapp.com/topic/12251/change-the-logic-for-assigning-waypoints-via-the-search-function</link><generator>RSS for Node</generator><lastBuildDate>Wed, 04 Nov 2026 13:58:03 GMT</lastBuildDate><atom:link href="https://forum.myrouteapp.com/topic/12251.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 04 Nov 2026 12:20:11 GMT</pubDate><ttl>60</ttl></channel></rss>
