<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Tracklog and route colors not ok to view]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I'm using a route to add Tracklogs to see how it works and I found a issue with colors:</p>
<p dir="auto">map Streets:</p>
<p dir="auto"><img src="/assets/uploads/files/1793784626673-6a5634e7-4464-4dab-97a5-b65a1f0ff86e-image.jpeg" alt="imagen.jpeg" class=" img-fluid img-markdown" width="1083" height="258" /></p>
<p dir="auto">Where is de "original route line"?<br />
This happens also with any light map.</p>
<p dir="auto">map Outdoor Dark:</p>
<p dir="auto"><img src="/assets/uploads/files/1793784705482-bae9bd63-b356-42a6-8b89-4cff51ae3a59-image.jpeg" alt="imagen.jpeg" class=" img-fluid img-markdown" width="1122" height="369" /></p>
<p dir="auto">This time route line is showed.</p>
<p dir="auto">Perhaps can you select other color for original route line?</p>
<p dir="auto">Also I noted that "dotted red line" is not showed on any route change.</p>
<p dir="auto">Regards,</p>
]]></description><link>https://forum.myrouteapp.com/topic/12233/tracklog-and-route-colors-not-ok-to-view</link><generator>RSS for Node</generator><lastBuildDate>Wed, 04 Nov 2026 11:46:58 GMT</lastBuildDate><atom:link href="https://forum.myrouteapp.com/topic/12233.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 04 Nov 2026 09:34:41 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Tracklog and route colors not ok to view on Wed, 04 Nov 2026 10:01:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lluis-arasanz" aria-label="Profile: Lluis-Arasanz">@<bdi>Lluis-Arasanz</bdi></a> Hi Luis,<br />
When you start a new route plan... you’ll see three small dots next to the export button; that’s where you’ll find the editor settings for changing the colour.<img src="/assets/uploads/files/1793786458635-32404.png" alt="32404.png" class=" img-fluid img-markdown" width="864" height="1939" /></p>
]]></description><link>https://forum.myrouteapp.com/post/87180</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/87180</guid><dc:creator><![CDATA[Peter Zehentreiter]]></dc:creator><pubDate>Wed, 04 Nov 2026 10:01:07 GMT</pubDate></item></channel></rss>
