<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Route planner doesn't want to follow the road]]></title><description><![CDATA[<p dir="auto"><img src="/assets/uploads/files/1793634077083-captura-de-pantalla_20261102_163456.png" alt="Captura de pantalla_20261102_163456.png" class=" img-fluid img-markdown" width="1236" height="824" /></p>
<p dir="auto">I'm just playing with the new web, and I first tried to plan a route, the one I know perfectly well, and I just found a problem, surely is some settings that I don't have quite right, the route planner keeps taking me out from the main road ( in the green circle), even when I try to put my waypoints on the dead centre of the road, moves them to where he thinks there's a road, in fact waypoint 4 is a street.<br />
Maybe it's not a problem of settings maybe is a problem of using the wrong map.</p>
<p dir="auto">The village is Ascara in the north of Spain, (Aragonese Pyrenees) in case you want to try.</p>
<p dir="auto">Thank you in advanced, and great job.</p>
]]></description><link>https://forum.myrouteapp.com/topic/12112/route-planner-doesn-t-want-to-follow-the-road</link><generator>RSS for Node</generator><lastBuildDate>Tue, 03 Nov 2026 03:43:13 GMT</lastBuildDate><atom:link href="https://forum.myrouteapp.com/topic/12112.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 02 Nov 2026 15:47:26 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Route planner doesn't want to follow the road on Mon, 02 Nov 2026 21:10:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/alexandre-marcel" aria-label="Profile: Alexandre-Marcel">@<bdi>Alexandre-Marcel</bdi></a>, This is because of a discrepancy between the MapTiler (visual) map and the HERE (or TomTom) calculation engine. These kind of discrepancies were also visible in the old planner, when you used a different overlay on a different base map. The new planner uses MapTiler maps always, regardless of the calculation engine, so these things will happen where there are larger differences between them.</p>
]]></description><link>https://forum.myrouteapp.com/post/86754</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/86754</guid><dc:creator><![CDATA[MotoCon]]></dc:creator><pubDate>Mon, 02 Nov 2026 21:10:08 GMT</pubDate></item></channel></rss>
