<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Club Add route → Copy: POIs, pause time and waypoint icon not retained]]></title><description><![CDATA[<p dir="auto">I have been testing the Club library in Safari on 30 October, using a private disposable test Club and a Moto route. The separate Link and Copy choices are useful, and folder downloading worked well: the copied route retained all eight waypoint positions and the full riding line exactly.</p>
<p dir="auto">I used <strong>Club routes → Add route → select a test route → Copy</strong>. The source had three route POIs and a stop at Cheriton House with a Photo icon and a 45-minute pause.</p>
<p dir="auto">After opening and reloading the independent Club copy, I found:</p>
<ul>
<li>The three POIs were absent.</li>
<li>The pause was zero instead of 45 minutes, reducing the total from 1h18 including stops to 33 minutes.</li>
<li>The Photo icon had become “No icon”. The note at that stop was retained.</li>
</ul>
<p dir="auto">The original remained unchanged. I then added it to the same folder using <strong>Link</strong> and downloaded the folder with POIs enabled. The linked route’s GPX contained all three POIs; the copied route’s GPX contained none.</p>
<p dir="auto">That suggests the POI omission occurs during Copy rather than downloading. Link may provide an alternative where keeping the original as the maintained source is appropriate; I have only checked this as the Club owner.</p>
<p dir="auto">Should Copy retain the route POIs, pause times and waypoint icons, or is there another step I should use? Keeping those details would be particularly useful when preparing an independent Club ride with planned stops.</p>
<p dir="auto">I have retained the test routes, interface records and GPX comparisons if useful.</p>
]]></description><link>https://forum.myrouteapp.com/topic/11998/club-add-route-copy-pois-pause-time-and-waypoint-icon-not-retained</link><generator>RSS for Node</generator><lastBuildDate>Fri, 30 Oct 2026 12:38:48 GMT</lastBuildDate><atom:link href="https://forum.myrouteapp.com/topic/11998.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 30 Oct 2026 11:06:11 GMT</pubDate><ttl>60</ttl></channel></rss>
