<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Using tracks]]></title><description><![CDATA[<p dir="auto">Is it possible to do the following?</p>
<p dir="auto">Create (draw) a track?<br />
Edit a track?<br />
Join and split tracks?</p>
<p dir="auto">Thanks</p>
]]></description><link>https://forum.myrouteapp.com/topic/11644/using-tracks</link><generator>RSS for Node</generator><lastBuildDate>Tue, 22 Sep 2026 20:28:57 GMT</lastBuildDate><atom:link href="https://forum.myrouteapp.com/topic/11644.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 22 Sep 2026 15:52:54 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Using tracks on Tue, 22 Sep 2026 20:14:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/berin" aria-label="Profile: Berin">@<bdi>Berin</bdi></a></p>
<p dir="auto">No, this it not possible</p>
]]></description><link>https://forum.myrouteapp.com/post/83783</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/83783</guid><dc:creator><![CDATA[Hans van de Ven MR.MRA]]></dc:creator><pubDate>Tue, 22 Sep 2026 20:14:04 GMT</pubDate></item><item><title><![CDATA[Reply to Using tracks on Tue, 22 Sep 2026 19:56:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/berin" aria-label="Profile: Berin">@<bdi>Berin</bdi></a> short answer - no, no &amp; no</p>
<p dir="auto">longer answer - in the MRA web planner<br />
you can create routes<br />
you can edit the routes by adjusting/adding Shaping &amp; Via points<br />
you can join routes &amp; if you have Gold subscription you can split routes</p>
<p dir="auto">you can then save/export a route to a gpx file as a track</p>
<p dir="auto">the gpx track file can then be re-imported to MRA as a track</p>
]]></description><link>https://forum.myrouteapp.com/post/83782</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/83782</guid><dc:creator><![CDATA[Brian McG]]></dc:creator><pubDate>Tue, 22 Sep 2026 19:56:28 GMT</pubDate></item></channel></rss>
