<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Tracklog correction]]></title><description><![CDATA[<p dir="auto">I have a tracklog of a ride I have done. Unfortunately the first part of this tour is missing. Is there a way to edit an existing tracklog in order to get a correct tracklog of my tour?</p>
<p dir="auto">The part where you see a straight line was not tracked properly. This is the part I would like to edit.</p>
<p dir="auto"><img src="/assets/uploads/files/1788187014875-img_9086.jpeg" alt="IMG_9086.jpeg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.myrouteapp.com/topic/11565/tracklog-correction</link><generator>RSS for Node</generator><lastBuildDate>Thu, 10 Sep 2026 03:44:38 GMT</lastBuildDate><atom:link href="https://forum.myrouteapp.com/topic/11565.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 31 Aug 2026 14:33:51 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Tracklog correction on Tue, 01 Sep 2026 20:09:21 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/j%C3%B6rgen" aria-label="Profile: Jörgen">@<bdi>Jörgen</bdi></a> <a href="/post/83108">said</a>:</p>
<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/guzzist" aria-label="Profile: Guzzist">@<bdi>Guzzist</bdi></a> <a href="/post/83105">sagte</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/christian-feurstein" aria-label="Profile: Christian-Feurstein">@<bdi>Christian-Feurstein</bdi></a>   next Idea to edit your tracklog:</p>
<ul>
<li>open it by MRA Routeplanner</li>
<li>select in Menue: use it as route</li>
<li>delete unnecessary route points (or move some)</li>
<li>save as gpx track</li>
<li>upload saved gpx file again in your folder Tracklogs as track<br />
By this, you don't need an external gpx tool <img src="https://forum.myrouteapp.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f609.png?v=9971e624bbc" class="not-responsive emoji emoji-android emoji--wink" style="height:23px;width:auto;vertical-align:middle" title=":wink:" alt="😉" /></li>
</ul>
</blockquote>
<p dir="auto">What about the missing part?</p>
</blockquote>
<p dir="auto">...that's the weak point: you need to be able to remember the route you’ve taken. Then, once you’ve turned the track into a route, you can add the relevant waypoints. And then, as mentioned, save it as a track again.</p>
]]></description><link>https://forum.myrouteapp.com/post/83112</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/83112</guid><dc:creator><![CDATA[Guzzist]]></dc:creator><pubDate>Tue, 01 Sep 2026 20:09:21 GMT</pubDate></item><item><title><![CDATA[Reply to Tracklog correction on Tue, 01 Sep 2026 19:39:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/guzzist" aria-label="Profile: Guzzist">@<bdi>Guzzist</bdi></a><br />
Thanks … I will try this once I am back at home! <img src="https://forum.myrouteapp.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f44d.png?v=9971e624bbc" class="not-responsive emoji emoji-android emoji--+1" style="height:23px;width:auto;vertical-align:middle" title="👍" alt="👍" /><img src="https://forum.myrouteapp.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f3fb.png?v=9971e624bbc" class="not-responsive emoji emoji-android emoji--skin-tone-2" style="height:23px;width:auto;vertical-align:middle" title="🏻" alt="🏻" /></p>
]]></description><link>https://forum.myrouteapp.com/post/83110</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/83110</guid><dc:creator><![CDATA[Christian Feurstein]]></dc:creator><pubDate>Tue, 01 Sep 2026 19:39:04 GMT</pubDate></item><item><title><![CDATA[Reply to Tracklog correction on Tue, 01 Sep 2026 18:24:24 GMT]]></title><description><![CDATA[<blockquote>
<ul>
</ul>
</blockquote>
]]></description><link>https://forum.myrouteapp.com/post/83108</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/83108</guid><dc:creator><![CDATA[Jörgen]]></dc:creator><pubDate>Tue, 01 Sep 2026 18:24:24 GMT</pubDate></item><item><title><![CDATA[Reply to Tracklog correction on Tue, 01 Sep 2026 15:49:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/christian-feurstein" aria-label="Profile: Christian-Feurstein">@<bdi>Christian-Feurstein</bdi></a>   next Idea to edit your tracklog:</p>
<ul>
</ul>
]]></description><link>https://forum.myrouteapp.com/post/83105</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/83105</guid><dc:creator><![CDATA[Guzzist]]></dc:creator><pubDate>Tue, 01 Sep 2026 15:49:01 GMT</pubDate></item><item><title><![CDATA[Reply to Tracklog correction on Tue, 01 Sep 2026 11:31:07 GMT]]></title><description><![CDATA[<p dir="auto">There is a possibility outside MRA. With a GPX editor, a .gpx file with the missing part and some manual work. Is it worth doing?</p>
]]></description><link>https://forum.myrouteapp.com/post/83102</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/83102</guid><dc:creator><![CDATA[Jörgen]]></dc:creator><pubDate>Tue, 01 Sep 2026 11:31:07 GMT</pubDate></item><item><title><![CDATA[Reply to Tracklog correction on Tue, 01 Sep 2026 11:22:02 GMT]]></title><description><![CDATA[<p dir="auto">This indeed cannot be corrected unfortunately.</p>
]]></description><link>https://forum.myrouteapp.com/post/83101</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/83101</guid><dc:creator><![CDATA[Corjan Meijerink]]></dc:creator><pubDate>Tue, 01 Sep 2026 11:22:02 GMT</pubDate></item><item><title><![CDATA[Reply to Tracklog correction on Tue, 01 Sep 2026 09:28:02 GMT]]></title><description><![CDATA[<p dir="auto">What exactly do you mean by checking tracklog files? After the ride I safed the tracklog and it was successfully uploaded. When looking into the stored tracklogs I found the showed tracklog with the first part missing. Where else do I find tracklog files?</p>
]]></description><link>https://forum.myrouteapp.com/post/83096</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/83096</guid><dc:creator><![CDATA[Christian Feurstein]]></dc:creator><pubDate>Tue, 01 Sep 2026 09:28:02 GMT</pubDate></item><item><title><![CDATA[Reply to Tracklog correction on Mon, 31 Aug 2026 15:44:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/christian-feurstein" aria-label="Profile: Christian-Feurstein">@<bdi>Christian-Feurstein</bdi></a> have you checked the track Log files<br />
If its not there you can't get it back</p>
]]></description><link>https://forum.myrouteapp.com/post/83090</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/83090</guid><dc:creator><![CDATA[Marinus van Deudekom]]></dc:creator><pubDate>Mon, 31 Aug 2026 15:44:41 GMT</pubDate></item></channel></rss>
