<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[routes opening as tracks on iphone]]></title><description><![CDATA[<p dir="auto">Hi<br />
2 questions<br />
1, when i open Myroute-app on my iphone it goes to the welcome screen, i go into routes and tracklogs and select the pre planned route from my library the route opens, showing the waypoints etc i then click on navigate and this comes up!<br />
<img src="/assets/uploads/files/1787565930781-mra.jpg" alt="mra.jpg" class=" img-fluid img-markdown" /><br />
I then click go, click the 3 dots to get to the menu and i find the road block function isn't there. Assuming this is due to it loading as a track not route, although it still has waypoints in.<br />
The only way to stop this is when I've selected the route and before clicking navigate i click on edit then the red return symbol it opens as a route with the roadblock function. I am opening them in the same conditions.<br />
Is there something wrong that it automatically opens my routes as tracks?<br />
2, In both routes and tracks when I tap the 3 dots to get to the menu and click on waypoints I can't alter any of them, I have to go out of the route and open it again and click edit, I thought you could edit waypoints or re-arrange them from the route.<br />
Thanks for any help</p>
]]></description><link>https://forum.myrouteapp.com/topic/11536/routes-opening-as-tracks-on-iphone</link><generator>RSS for Node</generator><lastBuildDate>Mon, 24 Aug 2026 12:22:33 GMT</lastBuildDate><atom:link href="https://forum.myrouteapp.com/topic/11536.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 24 Aug 2026 10:14:30 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to routes opening as tracks on iphone on Mon, 24 Aug 2026 11:45:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/crispey" aria-label="Profile: Crispey">@<bdi>Crispey</bdi></a> happy to see - you have detected the difference in the routing engine (list item in "Options") and the map overlays (list item on map).</p>
<ul>
<li>The map overlays don't have any affect to route planning. It's more gore your comfort to read the map.</li>
<li>The list items in "Options" makes a difference in routing and gives you the possibility to compare, how your route will looks like if you select:
<ul>
<li>Standard (Open Street map)</li>
<li>TomTom</li>
<li>HERE (MyRouteApp, Garmin)</li>
</ul>
</li>
</ul>
<p dir="auto">If you would like to share your route with others (my they uses TomTom) - and you can see, your route changes if you switch from Standard to TomTom - then you can enter more routepoints to force the engine to create same route by both options.</p>
<p dir="auto">If you want to use  MyRouteApp Navigation for your ride, you need to plan it with engine HERE, because this the only, the App is navigating a route!</p>
]]></description><link>https://forum.myrouteapp.com/post/82844</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/82844</guid><dc:creator><![CDATA[Guzzist]]></dc:creator><pubDate>Mon, 24 Aug 2026 11:45:40 GMT</pubDate></item><item><title><![CDATA[Reply to routes opening as tracks on iphone on Mon, 24 Aug 2026 11:21:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/peter-zehentreiter" aria-label="Profile: peter-zehentreiter">@<bdi>peter-zehentreiter</bdi></a>  Thank you once again I have found the extra function in the page menu of the app. I'm not sure how that got changed. Hopefully sorted now.<br />
Thanks again</p>
]]></description><link>https://forum.myrouteapp.com/post/82842</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/82842</guid><dc:creator><![CDATA[Crispey]]></dc:creator><pubDate>Mon, 24 Aug 2026 11:21:42 GMT</pubDate></item><item><title><![CDATA[Reply to routes opening as tracks on iphone on Mon, 24 Aug 2026 11:00:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/peter-zehentreiter" aria-label="Profile: peter-zehentreiter">@<bdi>peter-zehentreiter</bdi></a> Thanks for your quick response. I have the "navigation as track" disabled on my iphone and the Here default option is selected on the options menu top right corner of the computer not OSM, when I start to plan a new route in MRA it says " The selected mode only works with the Here/Tom Tom map". Routes are synced. Is there somewhere else that I have to select Here as default?</p>
]]></description><link>https://forum.myrouteapp.com/post/82841</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/82841</guid><dc:creator><![CDATA[Crispey]]></dc:creator><pubDate>Mon, 24 Aug 2026 11:00:05 GMT</pubDate></item><item><title><![CDATA[Reply to routes opening as tracks on iphone on Mon, 24 Aug 2026 10:31:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/crispey" aria-label="Profile: Crispey">@<bdi>Crispey</bdi></a> The way I see it, you planned your route using the OSM map.</p>
<p dir="auto">By default, the My Route app uses only the Here map.</p>
<p dir="auto">To prevent your routes from being started as tracks by default, you must first convert the route you planned in OSM to the Here map.</p>
<p dir="auto">And, of course, you must have disabled “Navigation as Track” in the app's settings.</p>
]]></description><link>https://forum.myrouteapp.com/post/82840</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/82840</guid><dc:creator><![CDATA[Peter Zehentreiter]]></dc:creator><pubDate>Mon, 24 Aug 2026 10:31:07 GMT</pubDate></item></channel></rss>
