<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Quad lock (or other) Phone mount ?]]></title><description><![CDATA[<p dir="auto">I'm using MRA Next on an iPhone with a Carpuride display through Carplay. So essentially, I don't need my phone mounted on the motorcycle while riding.</p>
<p dir="auto">To keep the phone's battery up, I hook it up to a battery pack and place it in the handlebar bag that I have on my R1200GS.</p>
<p dir="auto">The combination of workload (GPS+Carplay) and charging results in the phone becoming quite hot, with the heat unable to discipate as it is placed in a enclosed bag.</p>
<p dir="auto">Secondary, recently the OIS (Optical Image Stabilization) of my iPhone broke. I am unsire if this is now the result of vibrations with it being placed in the handlebar bag, or just age/bad luck with the phone now 6 years old.</p>
<p dir="auto">I'm likely to buy a new iPhone later this year and naturally want to protect it from overheating and hardware issues, so I started looking at Quad Lock mounting options. The assumption being that using a mount (including vibration dampener) would allow the phone to cool better as a result of air flow during riding.</p>
<p dir="auto">Wether having the phone loosely in a handlebar bag is worse than having it mounted on a vibration dampener is a big unknown.</p>
<p dir="auto">Looking at the different Quad Lock mounting options, the most obvious choices are not an option in my case:</p>
<ul>
<li>The handlebar is covered by the bag</li>
<li>The carpuride is mounted on the BMW Nav cradle, so that bar is also not an option</li>
</ul>
<p dir="auto">I am now considering the Brake/Clutch Mount but I have found very little examples of actual use online. So I was wondering: are people here using Quad Lock (or other) phone mounts other than the more common handlebar mount?</p>
]]></description><link>https://forum.myrouteapp.com/topic/11388/quad-lock-or-other-phone-mount</link><generator>RSS for Node</generator><lastBuildDate>Mon, 27 Jul 2026 13:05:14 GMT</lastBuildDate><atom:link href="https://forum.myrouteapp.com/topic/11388.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 27 Jul 2026 11:04:16 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Quad lock (or other) Phone mount ? on Mon, 27 Jul 2026 11:19:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/peter-zehentreiter" aria-label="Profile: peter-zehentreiter">@<bdi>peter-zehentreiter</bdi></a> Thanks for the tip, but the phone is in need of replacement either way. And honestly, the pricetag of the NOR7E simply does not make it an option for me</p>
]]></description><link>https://forum.myrouteapp.com/post/81445</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/81445</guid><dc:creator><![CDATA[Kirsten De Weerd]]></dc:creator><pubDate>Mon, 27 Jul 2026 11:19:57 GMT</pubDate></item><item><title><![CDATA[Reply to Quad lock (or other) Phone mount ? on Mon, 27 Jul 2026 11:13:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kirsten-de-weerd" aria-label="Profile: Kirsten-De-Weerd">@<bdi>Kirsten-De-Weerd</bdi></a> Before you spend money on a new iPhone and a new mount, consider whether it might be better to go with a completely different solution.</p>
<p dir="auto">DMD-NOR7E GPS Navigation Tablet powered by Android <a href="https://share.google/KEmqLDyrSf07LzPLD" rel="nofollow ugc">https://share.google/KEmqLDyrSf07LzPLD</a></p>
<p dir="auto">I’ve also spent money on various phones and mounts... and now they’re all just lying around...</p>
<p dir="auto">Since I’ve had the NOR7E, I haven’t had any unmet needs.</p>
]]></description><link>https://forum.myrouteapp.com/post/81444</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/81444</guid><dc:creator><![CDATA[Peter Zehentreiter]]></dc:creator><pubDate>Mon, 27 Jul 2026 11:13:47 GMT</pubDate></item></channel></rss>
