<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Manual &#x27;Compare Route calculation&#x27;]]></title><description><![CDATA[<p dir="auto">Reading the online support for "Manual 'Compare Route calculation'", there is a graphic provided that shows the three different routes for HERE, TomTom and OSM. The black line represents how the HERE map runs the route. Why is the black line running straight? I'm not seeing any road the black line is following?</p>
<p dir="auto"><img src="https://camo.nodebb.org/72759af71173158ef7eae3270838b4fc6cb06b5c?url=https%3A%2F%2Fs3.amazonaws.com%2Fcdn.freshdesk.com%2Fdata%2Fhelpdesk%2Fattachments%2Fproduction%2F12153124639%2Foriginal%2FsIbGqQ6ODEk_Wql5ZQSarNbRsMZR2xGUGQ.png%3F1732637666" alt="alt text" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.myrouteapp.com/topic/11304/manual-compare-route-calculation</link><generator>RSS for Node</generator><lastBuildDate>Wed, 08 Jul 2026 03:10:20 GMT</lastBuildDate><atom:link href="https://forum.myrouteapp.com/topic/11304.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 08 Jul 2026 01:21:04 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Manual &#x27;Compare Route calculation&#x27; on Wed, 08 Jul 2026 02:49:54 GMT]]></title><description><![CDATA[<p dir="auto">It is important to use the correct planning map for your navigation device.</p>
<p dir="auto">Each planning map comes with its own set of algorithms embedded within the map data to calculate which roads to use.</p>
<p dir="auto">The algorithms are unique to each planning map.</p>
<p dir="auto">So if you use MRA Navigation Next you should use the HERE planning map.</p>
<p dir="auto">After choosing the HERE planning map you can also click Always use this map for new routes to set the HERE map as your default planning map.</p>
<p dir="auto">From now on all new routes will be created using the HERE planning map.</p>
<p dir="auto">My screenshot below shows the planning map from HERE is selected and also the option to Always use this map for new routes.</p>
<p dir="auto">The overlay maps are separate to the planning maps and have no effect on route calculations.</p>
<p dir="auto">Think of them as clear sheets with extra information that you place over the top of the planning map.</p>
<p dir="auto">The planning map underneath does all of the route calculations.</p>
<p dir="auto">So with the HERE planning map selected you can then use any of the overlay maps.</p>
<p dir="auto">If you do not see the same blue menu bar with the planning maps that is shown in my screenshot, click Page menu first and then all of the same options will be available to you.</p>
<p dir="auto"><img src="/assets/uploads/files/1783478958083-830a53a8-1d62-4574-8d15-d0d600b02b60-image.jpeg" alt="830a53a8-1d62-4574-8d15-d0d600b02b60-image.jpeg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.myrouteapp.com/post/80621</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/80621</guid><dc:creator><![CDATA[Nick Carthew]]></dc:creator><pubDate>Wed, 08 Jul 2026 02:49:54 GMT</pubDate></item><item><title><![CDATA[Reply to Manual &#x27;Compare Route calculation&#x27; on Wed, 08 Jul 2026 02:46:30 GMT]]></title><description><![CDATA[<p dir="auto">And again but this time using the TomTom overlay map. I’ve zoomed in closer to make it easier to see that now the red TomTom route line is following the road.</p>
<p dir="auto"><img src="/assets/uploads/files/1783478776011-a1c0c70b-e73b-4eea-a542-cf716ddb4ef5-image.jpeg" alt="a1c0c70b-e73b-4eea-a542-cf716ddb4ef5-image.jpeg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.myrouteapp.com/post/80620</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/80620</guid><dc:creator><![CDATA[Nick Carthew]]></dc:creator><pubDate>Wed, 08 Jul 2026 02:46:30 GMT</pubDate></item><item><title><![CDATA[Reply to Manual &#x27;Compare Route calculation&#x27; on Wed, 08 Jul 2026 02:42:42 GMT]]></title><description><![CDATA[<p dir="auto">The same piece of road still using the HERE planning map but this time using the HERE overlay map. Note the black HERE line follows the road exactly.</p>
<p dir="auto"><img src="/assets/uploads/files/1783478497985-e3767674-d634-4683-a857-b116608e27c8-image.jpeg" alt="e3767674-d634-4683-a857-b116608e27c8-image.jpeg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.myrouteapp.com/post/80619</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/80619</guid><dc:creator><![CDATA[Nick Carthew]]></dc:creator><pubDate>Wed, 08 Jul 2026 02:42:42 GMT</pubDate></item><item><title><![CDATA[Reply to Manual &#x27;Compare Route calculation&#x27; on Wed, 08 Jul 2026 02:32:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/brett-bartick" aria-label="Profile: Brett-Bartick">@<bdi>Brett-Bartick</bdi></a> The example shows the overlay map from OpenStreetMap. You’ll notice that the red TomTom route line is also taking a different line. If the HERE overlay map was used the road on the map would look different and the black HERE line would follow it, the same as if the TomTom overlay map was used. This clearly shows the difference between all three maps.</p>
]]></description><link>https://forum.myrouteapp.com/post/80618</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/80618</guid><dc:creator><![CDATA[Nick Carthew]]></dc:creator><pubDate>Wed, 08 Jul 2026 02:32:29 GMT</pubDate></item></channel></rss>
