<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Adding a Via Point to or Edit a Round Trip]]></title><description><![CDATA[<p dir="auto">Not sure if this is something that may be already hidden in a menu, or a new suggestion.</p>
<p dir="auto">When creating a random Round Trip - once created, it would be good to be able to accept, but perhaps add a via point (such as a coffee stop near to the random route) within the app. Short of downloading the route and editing, I cannot see a way to do an edit to the route.</p>
]]></description><link>https://forum.myrouteapp.com/topic/11016/adding-a-via-point-to-or-edit-a-round-trip</link><generator>RSS for Node</generator><lastBuildDate>Tue, 26 May 2026 13:01:04 GMT</lastBuildDate><atom:link href="https://forum.myrouteapp.com/topic/11016.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 26 May 2026 11:16:51 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Adding a Via Point to or Edit a Round Trip on Tue, 26 May 2026 12:57:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/white.mouse" aria-label="Profile: white.mouse">@<bdi>white.mouse</bdi></a>, You are absolutely right. Converting the track to route is the only way to change it. But the result is not a track anymore <img src="https://forum.myrouteapp.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f609.png?v=ec1bbc54d40" class="not-responsive emoji emoji-android emoji--wink" style="height:23px;width:auto;vertical-align:middle" title=";-)" alt="😉" /> I interpreted the question as for on the move, or underway, but i might have been presumptuous with that. But if <a class="plugin-mentions-user plugin-mentions-a" href="/user/oneloosenut" aria-label="Profile: oneloosenut">@<bdi>oneloosenut</bdi></a> has the time and patience to convert the track to a route, your suggested method is perfectly fine.</p>
]]></description><link>https://forum.myrouteapp.com/post/78188</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/78188</guid><dc:creator><![CDATA[Con Hennekens]]></dc:creator><pubDate>Tue, 26 May 2026 12:57:53 GMT</pubDate></item><item><title><![CDATA[Reply to Adding a Via Point to or Edit a Round Trip on Tue, 26 May 2026 12:10:28 GMT]]></title><description><![CDATA[<p dir="auto">Formally You are right. But after that you are able to ad or move the route as you like! And as far as I know its the only way to edit a track!</p>
]]></description><link>https://forum.myrouteapp.com/post/78181</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/78181</guid><dc:creator><![CDATA[white.mouse]]></dc:creator><pubDate>Tue, 26 May 2026 12:10:28 GMT</pubDate></item><item><title><![CDATA[Reply to Adding a Via Point to or Edit a Round Trip on Tue, 26 May 2026 11:43:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/white.mouse" aria-label="Profile: white.mouse">@<bdi>white.mouse</bdi></a>, Yes of course, that's converting a track to a route, not adding anything to it <img src="https://forum.myrouteapp.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f609.png?v=ec1bbc54d40" class="not-responsive emoji emoji-android emoji--wink" style="height:23px;width:auto;vertical-align:middle" title=";-)" alt="😉" /></p>
]]></description><link>https://forum.myrouteapp.com/post/78176</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/78176</guid><dc:creator><![CDATA[Con Hennekens]]></dc:creator><pubDate>Tue, 26 May 2026 11:43:02 GMT</pubDate></item><item><title><![CDATA[Reply to Adding a Via Point to or Edit a Round Trip on Tue, 26 May 2026 11:41:09 GMT]]></title><description><![CDATA[<p dir="auto">Assuming you're using a computer, it's very simple. Create your round trip. Then select "Use."<br />
The route will then appear on the map. You can then select the "Edit route track" option. This will convert the track into a route with waypoints. You can then edit it as usual.<br />
Unfortunately, I don't know if it works the same way on a phone!</p>
]]></description><link>https://forum.myrouteapp.com/post/78175</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/78175</guid><dc:creator><![CDATA[white.mouse]]></dc:creator><pubDate>Tue, 26 May 2026 11:41:09 GMT</pubDate></item><item><title><![CDATA[Reply to Adding a Via Point to or Edit a Round Trip on Tue, 26 May 2026 11:37:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/oneloosenut" aria-label="Profile: OneLooseNut">@<bdi>OneLooseNut</bdi></a>, Any route you generate using curvy options or roundtrips technically are tracks (with no shaping or viapoints). Editing a track is not possible.</p>
]]></description><link>https://forum.myrouteapp.com/post/78174</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/78174</guid><dc:creator><![CDATA[Con Hennekens]]></dc:creator><pubDate>Tue, 26 May 2026 11:37:41 GMT</pubDate></item></channel></rss>
