<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Here&#x27;s some good news for a change; MRA is fantastic]]></title><description><![CDATA[<p dir="auto">The forum is usually filled with questions or problems; positive posts are rare. I’d like to change that now.<br />
Even though the new update still wasn’t available, I managed to drive through Germany and Belgium for four days without (much) trouble, thanks to MRA support.<br />
I prepared all four days’ routes in advance using the route planner on my computer. Every morning before departure, I checked the route on my tablet using Plan TomTom  to check for road closures. And to my surprise, MRA had already accounted for most of the closures on the routes. The only issue was that, as a result, some now-illogical Via and/or Route Points occasionally had to be moved.<br />
And whenever we encountered an unexpected road closure along the way, we could simply follow the indicated detour, after which MRA would pick up the route again once we were back on track. On a few occasions, we had to remove a missed waypoint while driving; this went without a hitch.<br />
We drove entirely online along the way, and this never caused any problems.<br />
Things also went (almost) perfectly during breaks, though I do have one caveat to note. During virtually all breaks, the connection between the phone with MRA and my Carpuride (Android Auto) screen remained active. Unfortunately, the one time that didn’t happen, things did indeed go wrong. On the Carpuride screen, after we had left, the cursor remained at the departure location. The route was visible, but it didn’t move with me. So I made an unplanned stop. Turned off Carpuride; stopped MRA; closed the MRA app; restarted MRA, restarted Carpuride, and . . . it worked again. Then I looked up the next waypoint in the waypoint list and tapped it to continue the route from there. And it worked!<br />
It might not be how it’s supposed to work, and I hope this will be fixed in the next (5.01) update. Apparently, it’s a glitch between MRA and Android Auto.<br />
Later, on the last day during the return trip, I took another break during which the MRA-Android Auto connection was supposed to be lost. So, just to be safe, I stopped both Android Auto (Carpuride) and MRA, and restarted them fresh after the break. And sure enough, everything was working perfectly again.</p>
<p dir="auto">In short, MRA performed wonderfully, and I hope the (beta) update with its many improvements will follow soon. On May 19, I have another big, one-day drive to test it out!<br />
Thanks to Cor-Jan and the team for all the work you’ve put into this!</p>
<p dir="auto">Translated with <a href="http://DeepL.com" rel="nofollow ugc">DeepL.com</a> (free version)</p>
<p dir="auto">Veelal wordt het forum gevuld met vragen of problemen; zelden wordt er een positief bericht geplaatst. Daar wil ik nu maar verandering in brengen.<br />
Ondanks het feit dat de nieuwe update nog steeds niet beschikbaar was, toch zonder (veel) problemen vier dagen in Duitsland en België gereden met ondersteuning van MRA.<br />
Alle vier de dagen van tevoren in de routeplanner op de computer klaar gemaakt. Elke dag ’s ochtends voor vertrek de te rijden route op de tablet nagelopen met Plan TomTom voor afgesloten wegen. En wat schetst mijn verbazing, de meeste afsluitingen op de routes zijn door MRA gewoon verwerkt. Alleen moesten er daardoor soms nog wat nu onlogische Via en/of Routepunten verplaatst worden.<br />
En daar waar we onderweg tegen een onbekende wegafsluiting aanliepen konden we gewoon de aangegeven omleiding volgen waarna MRA als we weer op de route terug kwamen deze route dus weer oppakte. Een enkele keer moesten we daarbij een gemist punt onder het rijden verwijderen; dit ging zonder problemen.<br />
Onderweg werd gewoon online gereden en geen enkele keer gaf dit problemen.<br />
Ook bij pauzes verliep het (bijna) allemaal goed, al moet ik daarbij wel een kanttekening maken. Bij nagenoeg alle pauzes bleef de verbinding tussen de telefoon met MRA en mijn Carpuride (Android auto) scherm in stand. Helaas, die ene maal dat niet gebeurde ging het dus inderdaad fout. Op het Carpuride scherm bleef de cursor, nadat we vertrokken waren staan op de vertrek locatie. De route was wel zichtbaar maar bewoog niet met mij mee. Dus een ongeplande stop gemaakt. Carpuride uit; MRA gestopt; MRA App gesloten; MRA weer opgestart, Carpuride weer gestart en . . . het werkte weer. Daarna in de routepuntenlijst het eerstvolgende routepunt opgezocht en deze aangeklikt, om vervolgens van daar de route weer te vervolgen. En het werkte!<br />
Het is misschien niet zoals het hoort en ik hoop dan ook dat dit in de volgende (5.01) update verholpen is. Kennelijk toch een bugje tussen MRA en Android Auto.<br />
Later, op de laatste dag tijdens de terugreis nogmaals een pauze gehad waarbij de verbinding MRA-Android Auto verbroken zou worden. Veiligheidshalve dus zowel Android auto (de Carpuride) en MRA, beiden gestopt om na de pauze gewoon fris op te starten. En jawel, geen vuiltje meer aan de lucht.</p>
<p dir="auto">Kortom, MRA heeft het geweldig gedaan en ik hoop dan ook dat de (beta) update met de vele verbeteringen nu zal volgen. Op 19 mei heb ik weer een grote, een daagse rit om het uit te proberen!<br />
Bedankt Cor-Jan en consorten voor al het werk dat jullie er in gestoken hebben!</p>
]]></description><link>https://forum.myrouteapp.com/topic/10879/here-s-some-good-news-for-a-change-mra-is-fantastic</link><generator>RSS for Node</generator><lastBuildDate>Sat, 09 May 2026 20:49:06 GMT</lastBuildDate><atom:link href="https://forum.myrouteapp.com/topic/10879.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 09 May 2026 18:34:09 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Here&#x27;s some good news for a change; MRA is fantastic on Sat, 09 May 2026 18:43:11 GMT]]></title><description><![CDATA[<p dir="auto">ik heb nu bewust gekozen voor barebone op iphone en ik verwacht dat dat ook beste keuze zal zijn. AA en CP is nu even niet mijn prio. mijn laatste trip 2 weken geleden op stabile versie werkte toen al probleem loos.</p>
]]></description><link>https://forum.myrouteapp.com/post/77177</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/77177</guid><dc:creator><![CDATA[Bouke Ent]]></dc:creator><pubDate>Sat, 09 May 2026 18:43:11 GMT</pubDate></item></channel></rss>
