<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Zumo XT3]]></title><description><![CDATA[<p dir="auto">Does Garmin changes routes made in MRA? I currently use the Rider 550 and I have to double check every route once it is uploaded into the tomtom software.<br />
So I am thinking of switching to the XT3</p>
]]></description><link>https://forum.myrouteapp.com/topic/10783/zumo-xt3</link><generator>RSS for Node</generator><lastBuildDate>Sun, 19 Apr 2026 22:29:57 GMT</lastBuildDate><atom:link href="https://forum.myrouteapp.com/topic/10783.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 19 Apr 2026 17:17:19 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Zumo XT3 on Sun, 19 Apr 2026 21:18:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sandelsan">@<bdi>Sandelsan</bdi></a> If you create a route in any tool and export it as gpx file - this file contains only the positions of the route points (not the drawn route line) you have set in the map.</p>
<p dir="auto">If you then load this gpx file into a navigation device/app they will load the given route points and will calculate a way (route) from one route point to the next point. So, that's the the reason why different navigation devices/apps calculate in result different routes. Because each navigation device/app has it's own algorithm.</p>
<p dir="auto">The way to force navigation devices/apps to the same result in route calculation is: to set many route points in the planning.</p>
]]></description><link>https://forum.myrouteapp.com/post/76393</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/76393</guid><dc:creator><![CDATA[Guzzist]]></dc:creator><pubDate>Sun, 19 Apr 2026 21:18:06 GMT</pubDate></item><item><title><![CDATA[Reply to Zumo XT3 on Sun, 19 Apr 2026 19:04:08 GMT]]></title><description><![CDATA[<p dir="auto">Normally XT3 does follow the WP’s, also TTR550 BUT calculations and instructions can be different. The only solution is more waypoints !</p>
]]></description><link>https://forum.myrouteapp.com/post/76386</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/76386</guid><dc:creator><![CDATA[AWDC LAO]]></dc:creator><pubDate>Sun, 19 Apr 2026 19:04:08 GMT</pubDate></item></channel></rss>
