<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Change Start Point and Waypoints]]></title><description><![CDATA[<p dir="auto">Hi - this might have been asked before or it might be a stupid question but is it possible to change the start point of an expert route and for the waypoints to also change to be in the correct order from the changed start point ?</p>
]]></description><link>https://forum.myrouteapp.com/topic/10752/change-start-point-and-waypoints</link><generator>RSS for Node</generator><lastBuildDate>Tue, 14 Apr 2026 10:09:32 GMT</lastBuildDate><atom:link href="https://forum.myrouteapp.com/topic/10752.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 13 Apr 2026 20:27:09 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Change Start Point and Waypoints on Tue, 14 Apr 2026 07:48:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/brian-mcg">@<bdi>Brian-McG</bdi></a>, check <a class="plugin-mentions-user plugin-mentions-a" href="/user/leike-lodiers">@<bdi>Leike-Lodiers</bdi></a> his method <img src="https://forum.myrouteapp.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f609.png?v=3e32ea04b7a" class="not-responsive emoji emoji-android emoji--wink" style="height:23px;width:auto;vertical-align:middle" title=";-)" alt="😉" /> Less convoluted!</p>
]]></description><link>https://forum.myrouteapp.com/post/76112</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/76112</guid><dc:creator><![CDATA[Con Hennekens]]></dc:creator><pubDate>Tue, 14 Apr 2026 07:48:35 GMT</pubDate></item><item><title><![CDATA[Reply to Change Start Point and Waypoints on Tue, 14 Apr 2026 01:44:13 GMT]]></title><description><![CDATA[<p dir="auto">Open route klick with mouse in the right corner on use route. Now klick any waypoint/shaping point where  you wanna start from and use the circled button. Make sure you make a extra waypoint next to the one you want to start from. If there's no waypoint nearby a part of the route will be skipped</p>
<p dir="auto"><img src="/assets/uploads/files/1776130541704-95ab1fc4-1e9d-4afa-abd7-b1462a83a95a-image.png" alt="image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.myrouteapp.com/post/76100</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/76100</guid><dc:creator><![CDATA[Leike Lodiers]]></dc:creator><pubDate>Tue, 14 Apr 2026 01:44:13 GMT</pubDate></item><item><title><![CDATA[Reply to Change Start Point and Waypoints on Mon, 13 Apr 2026 21:21:50 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/richard-ludlow">@<bdi>Richard-Ludlow</bdi></a> yes there is a way, but the way I know is a bit convuluted</p>
<p dir="auto">first you need a copy of the expert route in your list of route via the "Use Route" button as <a class="plugin-mentions-user plugin-mentions-a" href="/user/guzzist">@<bdi>Guzzist</bdi></a> explains<br />
you then need to split the route at the point you want the new start piont to be<br />
<img src="/assets/uploads/files/1776114985372-9b939409-0e7e-4337-91d0-f60e237292f5-image.png" alt="9b939409-0e7e-4337-91d0-f60e237292f5-image.png" class=" img-fluid img-markdown" /><br />
the route will now be in now in 2 parts<br />
open the second part<br />
you then need to combine the 2 parts but by placing the original first part at the end<br />
<img src="/assets/uploads/files/1776115263669-a7ff15e5-1b73-49be-a9a3-18e83b7af5e8-image.png" alt="a7ff15e5-1b73-49be-a9a3-18e83b7af5e8-image.png" class=" img-fluid img-markdown" /><br />
somelse may know a simpler way but this is the method I know</p>
]]></description><link>https://forum.myrouteapp.com/post/76093</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/76093</guid><dc:creator><![CDATA[Brian McG]]></dc:creator><pubDate>Mon, 13 Apr 2026 21:21:50 GMT</pubDate></item><item><title><![CDATA[Reply to Change Start Point and Waypoints on Mon, 13 Apr 2026 21:03:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/richard-ludlow">@<bdi>Richard-Ludlow</bdi></a> may I did not understand correctly. But If you found an interesting route from a Route-Expert, you can open this route. Then, in the opened route, tap the button [use route] - this will copy the route into your own library. Now you can edit this route - may move the starting point.</p>
]]></description><link>https://forum.myrouteapp.com/post/76091</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/76091</guid><dc:creator><![CDATA[Guzzist]]></dc:creator><pubDate>Mon, 13 Apr 2026 21:03:36 GMT</pubDate></item></channel></rss>
