<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[After upoad from Zumo 590: Tracklog &quot;current(1) is not identical with the single tracklogs.]]></title><description><![CDATA[<p dir="auto">When uploading from my Zumo 590 a tracklog it brings a file "current(1)". This file is not identical with the single tracklogs and it is also not identical to the route file. What track is this "current (1)"?  The current(1)-file also shows no date and time in opposite to the partial tracklogs. Thanks for any answer.</p>
]]></description><link>https://forum.myrouteapp.com/topic/10065/after-upoad-from-zumo-590-tracklog-current-1-is-not-identical-with-the-single-tracklogs.</link><generator>RSS for Node</generator><lastBuildDate>Mon, 08 Jun 2026 04:55:06 GMT</lastBuildDate><atom:link href="https://forum.myrouteapp.com/topic/10065.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 12 Oct 2025 14:24:46 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to After upoad from Zumo 590: Tracklog &quot;current(1) is not identical with the single tracklogs. on Mon, 13 Oct 2025 15:57:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/axel-zuleeg" aria-label="Profile: Axel-Zuleeg">@<bdi>Axel-Zuleeg</bdi></a></p>
<p dir="auto">Import all the tracklog files to mra and compare them with your route</p>
]]></description><link>https://forum.myrouteapp.com/post/70094</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/70094</guid><dc:creator><![CDATA[Hans van de Ven MR.MRA]]></dc:creator><pubDate>Mon, 13 Oct 2025 15:57:31 GMT</pubDate></item><item><title><![CDATA[Reply to After upoad from Zumo 590: Tracklog &quot;current(1) is not identical with the single tracklogs. on Mon, 13 Oct 2025 15:00:55 GMT]]></title><description><![CDATA[<p dir="auto">De ZUMO slaat in current.gpx tot ongeveer 10.000 punten op. Als dat aantal bereik wordt worden er punten overgeschreven naar een nieuw bestand; 1.gpx<br />
Daarna 2.gpx en zo verder.<br />
Deze staan je als je het navigatiesysteem aansluit aan een computer in de map /garmin/gpx/archieve</p>
<p dir="auto">als 1.gpx dus vol is (dus weer 10.000 punten wordt 2.gpx volgeschreven enz. tot 20.gpx<br />
Dan heb je dus 21 bestanden met ongeveer 10.000 punten per stuk.<br />
Het kan dus zijn dat je het eerste stuk van de track mist omdat deze naar een ander bestand verplaatst is door het toestel.</p>
]]></description><link>https://forum.myrouteapp.com/post/70090</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/70090</guid><dc:creator><![CDATA[white.mouse]]></dc:creator><pubDate>Mon, 13 Oct 2025 15:00:55 GMT</pubDate></item><item><title><![CDATA[Reply to After upoad from Zumo 590: Tracklog &quot;current(1) is not identical with the single tracklogs. on Mon, 13 Oct 2025 08:36:20 GMT]]></title><description><![CDATA[<p dir="auto">Could it be the track currently being recorded?</p>
]]></description><link>https://forum.myrouteapp.com/post/70078</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/70078</guid><dc:creator><![CDATA[Con Hennekens]]></dc:creator><pubDate>Mon, 13 Oct 2025 08:36:20 GMT</pubDate></item></channel></rss>
